woodbloke
I've been messing around with the LN Dowel Plate over the last couple of days and wondered how others use it as the holes are bigger on one side (in other words the section thru' a hole is a truncated cone) Assume I want to make a 6mm dowel. I cut the material to about 6.5mm square on the bandsaw and then use a blockplane to make it into an octagon. Are you supposed to waka :lol: it thu' the big hole first (to sort of compress the fibres) and then thu' the correct sized hole on the other side OR do you go straight into the 6mm hole and pass it thru' a couple of times? (second time just to clean up) Just interested, have found it to be a very useful bit of kit lately :wink: - Rob
