graduate_owner
I am not sure if liquid steel is the correct title here. I want to make a faceplate for my wood lathe, the thread being 1 1/4" x 9 tpi left hand. I have a set of taps and have used them to make a thread fitting out of hardwood but was wondering if I could make some out of metal. To that end I was wondering if there is a product that could be packed around a tap and allowed to garden to give the correct thread when the tap is withdrawn, something like epoxy resin but perhaps stronger and cheaper. Possible a fibre glass type product?
I have a spare headstock spindle for the lathe, so I was thinking along the lines of-
Put a release agent on the tap and pack the product around the tap and leave to set to create a 'blank'
Remove the tap and fit the blank to the spare headstock spindle
Mount the spindle in my metal lathe (I have a colchester master mk2, but not the skills to cut an internal left hand thread from scratch) and turn the blank to make a facelpate 'backplate'
Mount a disk to this backplate, drill and hey presto - a faceplate.
But - is there such a product to be had? Would glass fibre be strong enough for a faceplate backplate? Is there anything else that would work better? Or is my whole idea completely flawed?
Any suggestions would be appreciated - I don't mind criticism = if it is a daft idea then fine - say so.
K
K
