Rhossydd
Loosen off that allen bolt (it's not a nut) and there is a small amount of play in the blade. As long as you have a good reference, you can adjust them to properly square.transatlantic":1edoxmbp said:The larger 2 have a black hex nut, anyone know what that is for? .. I was wondering if it was to maybe adjust them? but below that is has 2 rivets, so that wouldn't work.
I bought a set, the largest one was a little out, but easily brought to acceptably true against my M&W square, the smaller two seemed as close as I could measure.
OK I wouldn't expect to do high precision work with them, but for a couple of quid each are amazing value for money and I'm sure will be useful to have around, but I wouldn't recommend anyone buy them as their only squares.
The built in spirit levels aren't much use though.
