Making a sideboard and starting to finish a few edges. Obviously the oil soaks into the end grain more, but after one coat it’s a little glossy, whereas the rest of the wood (all cherry) is barely satin. I’m guessing the end grain holds more oil so it’s harder to wipe off after 10 minutes.
Is there a technique for end grain? Should I oil more sparingly? Should I mop up sooner? Should I sand after each coat? I haven’t sanded or buffed with wire wool at all, just 1 coat applied and removed with cotton rags. Cheers
