Lever cap spring
GLFaria
21 Mar 2014
Portugal
Sorry if this is a dumb question, but it has made me curious ever since I found out some planes have one and some don't...
What is the lever cap spring really meant for?
I can see only two possibilities, and none of them seems that important, speaking of the work required of a hand plane:
1 - securing the lever in either the "up" or the "down" position (user convenience only?...)
2 - protecting the cap-iron from wear from the lever operation (?... the cap iron steel should be hard enough...)
Would anyone comment tell me the real truth about this matter?
To stop the rotating cam action friction from moving the blade assembly as the cam moves over centre? Although that would be only critical if you did not have a depth adjustment, still good practise though as cam can still be lubricated and the clamping force of the spring leaf/blade assembly friction contact remains unlubricated.
Thanks. I'm with CHJ. It was a dumb question, I should have thought of that reason!
No question is dumb, and my logic may be wrong, but it is good engineering practice to have a fixed locking plate to stop cam action movement on any such closure device.
Precisely! And I should have thought of that because I have worked for a time in tool and jig design - even if, for an excuse, that was over thirty years ago... Dumb!
It gets all the friction which is why it's made of hard spring steel. The Stanley/Bailey design is incredibly well thought out and developed in every detail.
