Okay, it's with a deep sense of shame that I realise it's October since I update this and November since I laid fingers on guitar parts.
Any road, have done a little more work though I still seem to be at the stage where a lot of effort goes in for little change - so do don't go expecting Waka or Nibbo-esque levels of progress!
Can't take credit for creating this, decided that for a first time me doing the fingerboard might be a bad idea, so bought this ebony one in from StewMac. Very nice it is too.
As you will have seen earlier on I did a lot of vascillating about whether to rout the wiring conduit before glueing the top on, I finally did after realising that my ply template needed some re-shaping. Took quite a while as I had to draw out the diagram onto the body and then clamp up for the routing - twice. Why did I decide to do a practice body at the same time..........
Anyway, that was a week of great progress, two routed grooves in a piece of timber. Gibson must be sh***ing themselves
To make sure that I ended up with the routed channel in the right place when I glued the top on, I referenced the body edges on the centre line at each end so I knew what my starting points were. This meant I had to trim a bit off, this little piece was the result, only showing cause it shows I should have a nice strong glue joint in there. Need to feel smug about something
Next up and tonights progress was glueing the tops up, a job I had to get right as it's very prominent. Practice body is some slightly figured sycamore, real body is flaming expensive flame maple. Employed the planing together in the vice technique as suggested by the ever helpful Mr BB for the maple. It wasn't happening for the sycamore though, so made use of the industrial sized planer in the class shop and had a superb fit in a few minutes. Always get a sweat on with a glue up, even when straight forward like this one, made sure I got the clamping right to even out the forces. These clamps aren't too strong, but then you don't want to apply a huge force when glueing a thin top for risk of distortion.
Lastly, I picked up a few things recently, couple of pickups from a guitar shop over in Halifax, loom, pots and switch from a guy in the UK, truss rod, knobs (which don't fit!), radius sanding block, binding and truss rod routing bit from StewMac - though not sure about the colour on the binding, bit too dark maybe. Lastly there should be a tornado router bit in there which will be used to rout out various cavities.
Realised I haven't taken any pictures of the pickup and pot cavity rout templates, will get those on. Swines took quite a while to make so they best work. Should be attaching the top to the body next week so progress should start to pick up
