leg spacing
Nicknoxx
18 May 2007
nr Monmouth
How far apart should I place my workbench's legs for maximum stability and ridgidity? The top is 2100 x 680 and I was thinking of putting legs 1/4 of the way along the length and almost the full width (less say 50mm for clamping)
What say you?
This is what I'm talking about
hi nicknoxx,
you need the legs nearer to the ends of the bench for max stability possibly leaving about 150mm overhang
woodbutcher
But while putting the legs at the ends like a dining table will make the whole structure more stable, it decreases the support for the centre of the table.
Is there a mathmatical way of working out where the 'best' place to put the legs is?
Hi Nick - I would also fit top rails between your leg frames.This will provide support for the middle of the bench top,and help avoid "racking" of the frame when planing long timber.
Andrew
