Nick Gibbs":20kazaen said:I think we'll have to show a drawing in the magazine!!!!! I think a lot of this comes down to how one stands relative to the board you are cutting. Some people will stand on the 'thin' side of the board (the waste side, normally), and some people will stand on the 'wide' side of the board.
If you stand on the waste side using a plunge saw your left arm, hip and leg will be closest to the saw. Holding the trigger with your right hand means you have to twist your body. You'd never do that with a hand plane. If you stand on the wide side of the board your right side is closest to the saw, and you can hold it like a hand plane, and work from right to left, but you are having to stretch across the board, which isn't ideal and sometimes isn't possible, and as someone else here notes, it can make the rail slip.
Mar_mite":22s9cfmt said:If I ever want to place the track on the waste side I just add on the kerf of the blade. So if I want a rip at 600, I'll measure 602 (and a bit). Leaving 600 once the cut is done.
