Hi All,
Very sorry I have not been able to respond sooner - I have been in sheer agony & in tears from unceasing back pain! In order to help convey things better, I have attacged a photobucket album of some pics of the actual speaker in a pre-cut 6mm ring (which is laminated so cannot be painted). Hopefully this will give a much better idea of things? Originally, I was going to just surface mount the rings so wanted a thin thickness but as I would now prefer for the rings to be inset into the thickness of the ceiling plasterboard, I think I can use a thicker (>6mm) ring thickness? The back of the speaker has a screw post which I can affix some strong cables & in turn secure those cables to joists so as to maintain tension & ensure the speaker is kept firmly in place (that is the idea unless there is a better way?)!. I have tried to answer your questions s best as I can below:
http://s296.photobucket.com/albums/mm17 ... %20Angles/
@Miles:
Q1) the thickness doesn't need to be 12.5 mm - it just has to be thick enough to take the weight and fixing means; you can get the flush bit with shims behind the board. This will allow you to use 12mm board which is going to be a lot easier than cutting a 16 mm board down to 12.5.
A1) I am open to any changes needed - I will need to go up into the loft to check whether the ceiling plasterboard is 9.5mm or 12.5mm thick - I have two sheets one on top of the other.
Q2) A turner will be able to knock these out fairly easily (sadly I just don't have time unless you mind waiting for a few months) however it would be useful if they had a speaker to check curves etc with
A2) I can supply a speaker if need be?
Q3) Are you planning to leave some fixings visible so that you can get at the speakers if you need to? There are some pretty good looking hex hole bolts around
A3) I was planning on it being a flush finish but have to admit, I really do not understand what you mean - but I can always get to the speakers in the loft above was my thinking
Q4) How confident are you of the hole that will be cut to hold the wood ring? Will this be very neat or will you need to fill it? This could influence the design in some way...
A5) I was of the thought that as I have two sheets of plasterboard in my ceiling, the hole does not have to be perfect as any rough edges will be covered by the flat surface of the speaker ring width which will be stuck to the upper sheet of plasterboard?
Q5) something that is nagging at the back of my mind that others far more experiences than me might be able to answer: how strong will the fine edge which provides the visual intersection with the sphere from below be? By the I mean will it a) be susceptible to damage b) provide enough strength and c) be robust enough during the production? If not I would consider either creating a slight step (thicker edge) or finding some way to take the weight of the speaker and then mask this with a plate or maybe just plastering in the speaker if you don't ever expect to extract it.
A5) I was hoping that as I would be using a rubbery type of glue with the fine edge & speaker body as well as strong wires connected at at screw post on the back of the speaker to ceiling joists, this would be strong enough? I am open to creating a thicker edge if need be?
@Simon:
Q) This could be done easily with a router and a jig, where are you Bazzy so that we can help find you someone local.
A) I am based in Harrow, NW London - hopefully someone will be close!
@Jumps:
Q1. As Miles has pointed out you can use 12mm mdf and, in 12.5mm plasterboard, you will simply have 0.5mm for your adhesive - sounds about right. The problem with 'flush' in this context is that you will have an unfinished plasterboard edge next to your neat painted ring - if you plan to fill and paint so that the ring disappears then I guess that's OK, but then I have to wonder why you are bothering with a ring at all (rather than setting them straight in the plasterboard for example). I think I would have a small rounded over lip on the outside of the rings to hide the plasterboard cut and provide a clean transition.
A1) I was planning to paint & getting someone to cut the oles so the ring edges should fit almost perfectly within the hole & rest against the upper sheet of plasterboard? I wanted the support rings for extra support, aesthetics & I fear that as I have two sheets of plasterboard in the ceiling & the speaker being a sphere, there will still only be a very small contact area & a straight cut hole will need lots of filling in which I do not want to do as it will mean securing the speaker in without ever being able to change it (in case it blows & needs replacing)
Q2). You show the sphere with the ring around the middle (which will of course be impossible if it's a one piece ring) but whether you have the bulk of the sphere above or bellow the ring you don't need to cut a curved side to the ring - simply cut on an appropriate angle to give a single line of contact at the lower face. The angle and size will depend on the position you wish the rings to be. The critical thing will be a nice clean lip at an aperture the correct size. If you want the ring just bellow the middle, with the speaker sitting in it, you will probably find a simple 45% angle will work - and a router will cut this easily.
A2) Thanks for the help - please have a look at the pics attached & advise if that will still work?
Many Thanks All,
Baz!
