I have recently had to move from my old work shop to a new one with a suspended floor. I set up my lathe (Axminster ATVS2030) today and ran it with a 10” bowl blank. At 300 rpm the lathe began to vibrate and the floor began to vibrate too.
Has anyone had this issue and if so how did you solve it?
I have tried putting the lathe feet over the joists with both feet at the headstock end over parallel joists ( bed running parallel to the joists ) , then I rotated it 90 and tried with the feet from each leg over the same joist ( bed running across the joists )
The second position allowed the lathe to get to about 420rpm before vibration started.. at 600rpm it was less bouncy but by no means steady.
The building i am in is rented so the possibility of pouring a concrete pad is out of the question... plus it’s about 3 foot of crawl space so would be very expensive..
Any help or advice would be massively appreciated.
Cheers. Jack
Cheers. Jack
