Hello,i am nearly finished building my lathe,i am having trouble finding a chuck to fit a 20mm shaft,if anyone knows if one can be got,or knows where to get one? i would be most grateful,if not i may be looking at making my own,ok thanks.
CRAFTY":1xq9rspg said:Hello,i am nearly finished building my lathe,i am having trouble finding a chuck to fit a 20mm shaft,if anyone knows if one can be got,or knows where to get one? i would be most grateful,if not i may be looking at making my own,ok thanks.
CHJ":1xq9rspg said:......If you intend using standard turning faceplates and chucks then the spindle nose needs to be made to some very specific dimensions.
See Here
yes it has been threaded to 20mm both ends,thanks i will look into it :mrgreen:woodpig":3mg7tw7x said:Crafty, have you had any kind of thread cut on the shaft? If not, I believe Record Power do a plain 19mm insert to fit their SC4 chuck that you may be able to open out to 20mm.
i know but i could not get a hold of the engineer that morning to have the threads changed to 1" by 8 tpi,when i did he had already done it to 20mmRobbo3":3rno3jix said:We did try to warn you about headstock threads!
Now you need to know the thread pitch. If it's 1.5 or 2mm you can at least get an SC4 chuck & thread adaptor but you are restricted to using that chuck or others with the same internal threads as the adaptor. If the pitch is something different your only hope is to get an adaptor machined to a common headstock thread, perhaps M33 x 3.5.
ok they come with both 1.5 and 2mm pitchesCRAFTY":3h8xkas8 said:SC4 thread adapter,20mm,ohhhhhh yes,i be getting it A.S.A.P,great job WOODPIG,thanks a lot,save me messing around with making one and adding more danger,cheers :mrgreen:
my lathe is getting some bling \/
Look at the links I keep providing in previous posts, the Axminster chart gives all the details. There are several other references but that's as good as any for someone to start with.Keithie":799joft9 said:I'm enjoying crafty's threads as I'm learning loads.
Please can someone explain what 'register' is (not the one they take at old folks homes in the morning to make sure everyone is still there!) ..thanks
CRAFTY":2za7o358 said:so will this jaw fit the adapter? record sc4
great stuff,i will put them on my list,thanks.woodpig":1a4jywg7 said:CRAFTY":1a4jywg7 said:so will this jaw fit the adapter? record sc4
Yes. When you're ready to get a chuck the SC4 is pretty good for the money. There's also a good range of accessory jaws that fit it.
Keithie":2una99b5 said:Would those who've been advising him on here be liable if there was?
