John. B
Now on Ebay
I have a new toy to play with (lathe) so I must make room. ( Shed's not very big)
So. I am selling my Tyme Avon.
It is 240v 50hz single phase 560w (3/4hp)
4 Speed:
- 470rpm
- 750rpm
- 1150rpm
- 2000rpm
via poly V-belt
headstock/tailstock - 2mt,,, headstock swivels 180 degrees
H/stock drive spindle 25mm x 2mm ISO
Diameter over the bed bars 280mm
----"-----with headstock 90 degrees 500mm
----"-----with headstock 180 degrees 580mm
It comes with an outrigger for outboard turning,
3 x rests - 245mm and 115mm straight and 280mm curved.
100mm faceplate
a live centre, and knockout bar.
A service manual, (Original)
and if you happen to have an Axminster precision chuck, a backplate to fit it.
It also comes with a very sturdy bench. The size of this is:
1530mm long
540mm at the bottom 450mm at the top - (A-shaped)
and 780mm high.
The lathe is heavy, the bench is extremely heavy :shock:
£250.00
Or make me an offer :lol:
Collect only, will need a van I reckon. Well at least for the bench, You can get the lathe into a car with little or no problem.
Romford Essex area.
Will leave it on the forum a few days then put it on the bay
(The tools behind the lathe are not included)
(Only those on the bed bars) 8)
John. B
4 Speed:
- 470rpm
- 750rpm
- 1150rpm
- 2000rpm
via poly V-belt
100mm faceplate
1530mm long
and 780mm high.
£250.00
Romford Essex area.
John. B
