scooby
I’ll be moving soon to a house with a much smaller garage so I’ve decided to try and sell my lathe and turning tools, etc. I’ve not done much for a while so I’ll hopefully not miss it.
KS Midi FU 350 Lathe. Bought from Hope Woodturning in January 2021(I can give a digital copy of the receipt). Details here https://hopewoodturning.co.uk/lathe...fu-350/114/midi-fu-350-woodturning-lathe?c=75 Appearance, it isn’t mint but its in very good condition and runs perfectly. I think it’s the same machine (or very similar) as the Axminster Professional AP350WL with a different colourway.
All the original parts are supplied and I’ve included some hss tools and accessories, which I’ll list below:
It’ll have to be collected from Greater Manchester
Included:
Lathe
Homemade stand
4 prong centre
Live centre
Dead centre
Centres for using the lathe as a pen press
Original faceplate mounted on 305mm mdf Velcro sanding disc (and spanner to remove if needed)
Sanding platform and homemade extraction box (not pretty) to connect to a vac.
Plastic centre finder
Homemade 100mm extraction hose holder
Home made bowl sander and selection of 50mm sanding discs
Record power 13mm MT2 drill chuck, key and drawbar
Internal calipers (open up to about 6”)
Record power 100mm face plate
Selection of polishing mops, menzerna compounds and carnauba (and pigtail that can be used in drill chuck)
Few small turning blanks (top to bottom: walnut, tamboti, sycamore or maple, yew, ash and brown oak.
Tools:
3/4” roughing gouge
1” oval screw
Homemade hss 40mm wide scraper
Homemade hss 12mm parting tool
Included:
Lathe
Homemade stand
4 prong centre
Live centre
Dead centre
Tools:
3/4” roughing gouge
1” oval screw
