Latest projesct
sawdust maker
24 Jan 2007
East Yorkshire
Hi
Would like to show off my latest project. Got the plan from Paul Richardson's book, Making Classic English Furniture.
It's the first real bit of fueniture I have made and the first hand cut dovetails I have made. The drawers are oak lined with Mahogany fronts. A mahogany curl veneer is on the top and drawer fronts. Although it doesn't show very well. The top is crossbaned in Satin wood with a 1.5mm boxwood and 1.5mm Ebony strip between the mahogany and Satin wood. The edges of the drawers and legs have the Boxwood strip. The top is made of MDF, but I wish I had used ply. I had to dampen and press the curl before I could lay it. I don't think it was dry enough, because although I put a backing veneer on the top, the top has developed a very slight bow. If it gets any worse I will have to make the top.
Added 14:10hrs Saturday 27th.
Thanks for all your compliments. My head is so big now I don't think I will get back into my workshop!
In answer to:-
Alf. It took about two months working evenings and weekends.
Lord Nibbo. I am a newby, not sure what a Furniture thread is?
Waterhead37 The top veneer is only .06mm not 1.5mm (didn't know you could get it that thick). I flattened the curl in a press sandwitched with paper towels. But even though I changed them three times and left it 24 hours, I think I should have given it mor time.
Woodbloke. The top veneer was balanced with one underneath. But it didn't need flattening so was drier.
Shivers. I used PVA on the top veneer and an iron on glue for the backing veneer.
Thanks again all.
Very nice. I like the boxwood trim around the drawers - Looks like you got a nice finish on there too. Initially I thought the the drawer handles looked a bit big, but I think it's just because they're so shiny and new at the moment. Once the've had a bit of use, they'll probably darken a little and not draw the eye so much. (or maybe that's just the photo)
Good work sawdust maker :D
Hi
I like what you've done, you must be feeling very pleased and with good reason, look forward to your next project.
Cheers Alan
That is a very fine job for a "first real" one and it is nice to see such a classic piece. Congratulations.
I find curl veneers can be very difficult to get flat, especially if you are using a thick one. I found 1.5mm mahogany veneers very tough and scrapped several leaves/substrates whilst making up panels with them because I used them before they were dry (and I was using a vacuum press).
IIRC Paul Richardson talks about keeping stuff flat (even without a balancing veneer) using newspaper during the drying process?
Very nice work =D>
You have proved that you don't now need to follow a plan.
For your next project - design your own. It's even more fun!
Brad
Beautiful, It looks better than any of the 5 featured in the interesting furniture thread.
Congratulations on a stunning piece of work.
Phil
That's a lovely piece SDP. Do you have any WIP photos? And how about some piccies of the drawers and the underside of the table?
If I had made that I'd be chuffed to bits! I hope you feel inspired to make some more. Not heard of the Richardson book. How do you rate it?
Lovely piece of work - Paul Richardson's book is a good one IMO
Did you put a counter balancing veneer on the underside of the top?....if not then this may be the reason that the top has a slight bow as the surface veneer shrinks slightly - Rob
Well done --nice job, what kind of glue were you using for the top? & what methods to glue the veneer down.
