Munty Scruntfundle
Hi folks. I'm trying to locate, without much success, a large collet system for a lathe.
I've used a couple of ER32 and 5C chuck/collet systems with good success, but being limited to 20/30mm is becoming a problem as I'm starting to work on larger parts. It's not often I need the larger option, but when you do, you do!
The new lathe coming would be, I guess described as mid sized with good space available over the bed. Does anyone use such things? Any suggestions?
Many thanks.
Many thanks.
