Knock down Domino joinery. Great idea?
Essex Barn Workshop
11 Jul 2020
Loughton, Essex
I have just watched this video, stick with it because initially I thought 'looks great, but why bother?' and then the actual idea comes out.
To me, it looks like a great idea for furniture when you might need to disassemble at some point, or even make it for easy transportation and then fix at final assembly.
Whatever, surely worth a look?
In the screenshot, the hole is extremely near the end of the Domino. That would appear to be a weak point.
The hole also appears to consume roughly 1/3 the vertical dimension. Is that also a concern?
Festool sell a metal-and-plastic knock down domino that you can secure with a screw. If disassembly is really key, I'd just use that, despite the cost as it's less hassle.
Please bear in mind that part of her thought process was the look of the joint, and the above points aren't obviously taking that into account. I agree, for pure ease of takeapartability (new word!) there are other options, and I would use a slimmer dowel but look at it as an overall idea and I think it has uses.
Used a similar principal in the past, however I just put a screw in, rather than a dowel, inside the cabinet, and not seen.
