Kity Mortice Machine - Model 652
Nick H
New member
12 Jul 2007
Shropshire
Hello - New to this.
Would anyone know where I could obtain a manual for a Kity 652 mortice machine.
I have recently purchased this machine, I think there must be a part missing as I am unable to fit a standard mortice chisel.
Thanks for any help.
Nick H
Nick,
I'm not familar with the KITY model number that you quote but the morticer orignally fitted to my KITY combi machine does not take mortice chisel but instead uses something similar to a single blade router bit in a drill chuck.
I kept banging my knee on it so I removed it years ago (the mortice attachment!!)
hth Bob
Hi Nick,
Welcome to the forum. :D
Sorry I can't help with the manual, hopefully someone will be along who can. 8)
Kity did a 2652 combi machine which would have had a slot morticer on the side. There is usually a male thread on the end of the planer block that takes a drill chuck whick in turn takes a slot mortice chisel.
The same slot morticing attatchment was available with its own motor so it could be used as a stand alone. Any chance of posting a picture?
You should be albe to get slot morticer bits but beware as the 2652 takes LEFT HAND cutters. The ones for the current Bestcombi 2000 will fit, Contact your local kity stockist or talk to NMA, or Richard from NMA may see this post and answer.
http://www.nmauk.com/
JAson
Hi, I'm also after some of those left hand slot cutters , i've just had alook at the link there doesn't seem to be any cutters.
Alex
Hi Nick
I have a Kity 652 morticer as part of my CK26. It came with a right hand chuck - so turns the same way as a normal drill. I still have the rather slim manual that came with it. I can copy it to a pdf, more an issue as to how to post it. Do you still need it?
Norman
Nick H
Hi Nick, I too now have a 652 morticer that I purchased this year. Did you ever get to find a manual and / or parts list for it, if so any chance of a copy please?
Many thanks
Peter
Many thanks
Peter
That was Nicks one and only post and it was 15 years ago so don't hold your breathe.
Hopefully somebody else will be able to help you out though 🤞
