tmitch45
HI All,
I have been lucky enough to be given what I think is a Kity K5? On the stand it says Bestcombi. Its in working but rough condition and I'm in the process of stripping it down to renovate and rebuild. I must admit I'd never heard of the Kity brand before this but in a discussion on a FB page tells me its a pretty good machine and around 20+ years old? Now unfortunately my parents neighbour who gave me the machine is in poor health so wasn't able to tell me much about the machine at all. I've searched on 'google' and I understand it either came with or had the option of a mortiser and a spindle moulder? both of these are missing on mine and I have no instructions. There are a couple of things I'm intrigued about and would love your help with as I want to do right by the guy who gave this to me and fully restore and modify it to better than its former glory.
1. There are scratches on the table saw table and some pain spills etc. I want to carefully machine polish this but it looks like there is a protective darker grey coating on it. its this correct and would it matter if I polished this off as I intend to wax it?
2. The fence for the table saw is damaged and not accurate can people recommend an upgrade one?
3. The table saw blade isn't in line with the 'T' tracks, is there a way to adjust this into alignment?
4. The surface plainer works well but when putting wood through the thicknesser there are lines across the wood which I think is from the ribbed infeed roller? Is this a known issue and how can it be improved or eliminated?
5. There is a large pully wheel with 3 large holes and 3 smaller holes (see photo) which is part of the drive mechanism for the thicknesser rollers. There is a huge amount of lateral play in this is that normal and how can this be improved as its reducing the tension on the small drive belt.
Many thanks for any help and advice you can give me in my quest to restore this. I also plan to build a modified cart so its more mobile and fits in my workshop particularly as the spindle moulder is missing so there is a huge space. I'll keep all the old parts so at any time I can return it to stock.
