Lons
Kity K5 (Mark 2), 5 function combination woodworking machine
200mm saw / 150mm surface planer / 150 x 100mm thickness planer / spindle moulder / slot morticer, 075kw (1hp) motor
Owned from new, clean and in very good condition, all works as it should. No issues though it had a minor repair some time ago to the spindle moulder cast mount for the rise and fall mechanism. It was cracked so a steel strengthening plate was fitted and it is stronger than original and works very well
There are a number of extras including Saw table extension and long fence, easily and quick to fit and remove if space is tight, box joint attachment, Spindle ring fence accessories and along with the standard tooling there are 2 extra pairs of planer knives, 15 french head cutters, 3 spindle slotting blades, extra sawblades, spare belt, original Kity hard backed books and of course instructions. Check the photos for details.
Machine is located in Northumberland (NE65 8) and I'm looking for £500.
I'm not desperate to sell just making an effort to please the missus by appearing to clear out little used equipment so if no interest here I'll advertise locally and see what happens. PM me if any interest.
I also have for sale separately a number of additional items including planer blades, spindle slitting sawblades, slot mortice bits, spare belt x1, cutter block with cutters and 30 – 20mm reducer in case, sanding drum kit. which I'll list for sale in due course.
