Apologies, clearly too much time in the sun ! It’s a 619 stated on the plateThe thread is titled 619. The question aska about 1619. Could you please make your mind up.
1619 specifcations here:
https://web.archive.org/web/20080509154542/http://www.dbkeighley.co.uk/masters/kitty1619.htm
619 specifications here:
https://www.hoechsmann.com/en/article/45123/bench_saw/kity-bela_619.html
1619 says 1800W; 619 says 2200W. You can work on the basis of 4A per kilowatt.
Actually, you can't. Not with the induction motors used in these machines.You can work on the basis of 4A per kilowatt.
Yes, you're missing somethingNot sure if I’m missing something, but a 2,200W machine running on 230V would pull 9.56A (I=W/V), so you would be OK on a 13A plug top. The issue if you are blowing fuses may well be in rush current.
The part you are missing is called reactance, it consumes energy whilst delivering nothing in the way of useful energy because it is only resistance where energy is disipated. Your equation is ok for Dc and some Ac circuits providing you use RMS values. Capacitance and Inductance cause the voltage and current to be out of phase so this phase needs to be taken into considration when looking at total current used because these quantities are charged / discharged at twice the line frequency. Motors will show something called Cos Theta which is the ratio of active power(kW) to apparent power(kVA) which gives reactive power(kVAR). With a power factor of 1 your equation holds but with motors you get a PF of less than 1 because of the reactive component so more power is needed but this is not reflected in the output.Not sure if I’m missing something, but a 2,200W machine running on 230V would pull 9.56A (I=W/V)
All depends upon the current instalation and if the cables are sufficient to carry the current under both normal loads and fault conditions, hence why just swapping a type B device for a type C is a bad move unless you can measure the loop impedances.Many thanks for all the advice - is a 16amp supply costly?
