Terry - Somerset
We completely replaced our kitchen about 12 years ago . It is now beginning to look tired. It was also done in something of a rush (personal reasons) so did not include all the bells and whistles that should have been fitted. The work I am planning is:
1. Replace hob (cracked) and double oven (grill element needs replacing) - hob induction not ceramic, oven electric
2. Convert most under worktop cupboards to pull out drawers - ease of access
3. Replace tiles
4. Worktop - this is where I would appreciate some informed advice!
Hob and oven should fit existing apertures. Power supplies are already there. Most companies offer some form of fitting service - albeit slightly rip-off! (2) and (3) I will do.
The existing worktop is a laminate. Some of the joins are uneven (swelling < 1mm), the existing tiles are the upstand with some leakage behind the sink, and the once matt surface is smooth in parts due to use. The kitchen units are sound although I need to fit soft close hinges and may/may not change doors and handles.
So the options are:
1. Replace laminate with more laminate - probably cheapest solution
2. Replace with wood - reasonable cost but higher maintenance
3. Replace with Corian, acrylic or similar - possible wear issues - fairly pricey
4. Replace with granite slab - nice but most costly
The other alternative I have come across is for an overlay of typically 6-10mm. This retains the existing worktop as a base - a definite plus point, and seems moderate cost (between wood and acrylic) as less material used.
My questions to the ladies and gentlemen are:
- do you have any experience of overlays, resistance to high temps and marking
- can they really be fitted in a day
- have you found any negatives
- do you feel they are good value or a waste of time and money
With thanks for any feedback!
3. Replace tiles
So the options are:
