ajmoran
Screw up as in it's held together with screws and done quickly.
I needed some kitchen cabinets of specific dimensions and decided to make them from Melamine Faced Chipboard and build them in the kitchen using pocket hole screws as a weekend project. Here's the design (click to visit large version):
And here's a photo of the cabinets on their way to completion:
One of my customers operates a cutting service so I sent them the cutting list and their Beam Saw cut all the components for the project out of some very nice Egger MFC. All showing edges were edgebanded with 2mm matching PVC. The end result will be a robust carcass that any German Pharmacy would be proud of
First off the doors and sides were laid out on the floor and the position of the shelves and hinge locations marked. The 'client' got involved directly with the shelf positioning so we know it will fulfill the storage brief
The doors were dimensioned for 5mm separation so a 5mm drill bit spaced them at the right relative position.
Then I used a simple jig to drill pilot holes in door and side. Note the two rough holes on the left of the jig are 'viewing holes' so that I can see pencil marks made on the MFC where the hinges are needed.
The hinge holes are on the right. I'm using Blum Inserta which need three holes drilled. You can also notice the texture of the MFC in this picture.
After drilling the pilot holes, this piece of ply holds the door and side in position whilst I get on with the other hinge locations
For drilling the 5mm shelf pin holes in MFC I advise against using cordless drills (well my cordless drill anyway). Here's one done with a cordless drill:
And here's one done with a corded drill brought to full speed before touching the melamine:
I'll follow up with how the cabinets were put together with pocket screws.
Andrew
Andrew
