This thread actually made me curious about sled usage. Are tablesaw sleds used in the uk?
the cat amongst the pigeons.
I'll wager everyone's got a sled, EVEN Tiddles, who as we speak is rushing to fit a guard so he can post a pic
Psst, your perspex sheeting is stored next to your plywood
it comes with guards and instructions, take them off and cut your fingers off... personal choice.
Sigh....no it won't. and ill even wager that a fair number of accidents of fingers impacting saw blades did so with a guard in place. You reckon thats a fair assumption ?.
But as has been explained and pointed out umpteen times on this thread alone. Using push sticks and not having your hands within the recommended(by the HSE no less)300mm of the blade is the key. As is using long(minimum 450mm push sticks
You put your hands up close to the blade, guarded or not and you are asking for trouble. The blade just doesnt jump forward, like its possessed out the Omen.
Can you explain how you can impact your blade when your fingers are nowhere near it ?. Clearly not.
Oh yes, you can have an accident without a guard being fitted, nobody is disputing that, BUT, to do so you must break hse golden rules and have your hand close to the blade.
We should also point out that the saw blade projects through the workpiece a mere 1/8th of an inch when ripping or making cross cuts. So should you be crazy enough to actually place your hands on the workpiece and push it through the saw and maybe shut your eyes while doing so, and have your hand in line with the blade so you inadvertently impact it, you will receive a number of very very nasty cuts, but it is unlikely you will amputate anything.
I have to confess here that I break this rule, and have the blade project about 1/4", its so the dust clears off the tooth and the dust extraction on the guard gets it better. I know a pure rebel.
PS I dont wear a bike helmet either, unless of course im riding offroad.
