Hi
This is a very basic question but I can't find anything about it online.
To what extent does removing wood for a joint, e.g. Half the width for a cross lap joint, affect the strength of the timber? Obviously it creates a weak point. But how much does the other piece of wood that fills the hole make up for it?
I'm trying to choose to joint two pieces of 38mm x 63mm softwood in a T-shape in the horizontal plane, and needs to be fairly strong for a dining table. I am considering two 5mm screws, or a T-lap joint (or a M&T but can't see any advantage over the lap joint). Screws would be quicker but may not have as much shear strength, and presumably would also weaken the timber. The joint will be hidden so the aesthetics are irrelevant.
Many thanks
Many thanks
