Matthew Lawson
New member
I bought a new Jet JPT310 in February 2015 and have had a recurring problem with it. After approx 20-30 minutes use, the machine will not restart for perhaps 30 to 90 minutes. Occasionally the machine cuts out in use, but this is the exception. I assumed the problem was due to a faulty overheating sensor and both the motor and start switch have been replaced by the supplier but this has not cured the problem. The blades are kept sharp and material removed is generally no more than 1mm. Anecdotally, it has been suggested to me that the switch mechanism is not heavy duty enough for the machine but this is beyond my expertise. Machine has been used for perhaps 50 hours since new.
I would appreciate any feedback on similar problems or ideas to cure it.
Many thanks
Many thanks
