PaulO
Just had mine delivered today.
Spent most of the day setting up proper 16A outlets with a new consumer unit (all part P, obviously). Then cleaning off the gunk and carnauba waxing the tables.
I notice that since Mark W's post the design of the fence has changed. It is now machined, and doesn't have the grooves on it that it used to have. I also notice that the locking and thicknesser drive handles are no longer zinc passivated. (they may be galvanised, but I can't be bothered to go back to the workshop to check now)
The fence appears fairly flat using my engineers square, there is a slight hint of concavity, but not enough to get a feeler gauge in. It might be my engineers square, which has had a bit of an abused life.
If I was to criticise anything, it would be that the man who stuck the angle sticker on the fence was out by a few degrees. Given that it will be set at 90 degrees with a square for 95% of the time, this shouldn't be an issue.
Now I just need to make some more shavings and see how I get on.
