Yes you are spot on ChaiLatteThanks.
It appears there are two broken parts: 1) the shaft whose end has a flat on it and is gold in colour; 2) the ring-shaped piece (like a grey polo mint).
The shaft would be easy to reproduce either by sending the broken one to someone to copy or by making a drawing and sending the drawing.
What is the other part and to what does it join? From the initial phtographs in the opening post, is it a boss that has broken off the gear?
I took the gear out and cleaned it I can see clearly what has sheared off
View attachment 185307How much space is there around the boss of the gear when it is installed?
If there is enough, you could repair as the blue bit in the above image. Nothing there would need to be very precise. Clean everything and glue it all together with JB weld. Once it has set, drill some 3mm holes (at 120 degree intervals) vertically through both parts. Drill 2 holes horizontally at 90 degrees to the keyways. JB Weld some 3mm diameter steel pins into the five holes. If you were keen, maybe a coupe of 2mm diameter pins tying the two original parts of the gear together.
The shaft is easy enough for a machinist to reproduce. It looks like a fatigue failure at the end of the pocket for the two keys in the shaft. The new version might do better with woodruffe keys, which taper out to nothing at the ends so have less stress concentration.
Part 27 is a LABEL for the motor. Motor is part 1. It is listed here (will be 110v) for $365: https://jettools.com/motor-jwds1632-201
If the gear repair described above was possible, that, along with a new shaft, would be less than that. Even if someone charged you £200 for the work, you still spend less. In your original photos, the OD of the gear bottom right will determine how large a collar you could put around the boss on the gear. The gear looks to be a powder metallurgy item so soldering or brazing would not be possible, hence the suggestion of adhesive backed up with mechanical restraint.
Thanks again ChaiLatte, as you can see from the photo there is no room which is a pity as I would have had a go at thatHow much space is there around the boss of the gear when it is installed?
...as you can see from the photo there is no room...
...one final question how do I clean the grease off
Thank you Blister
Thank's for the links SilkenYou should be able to find someone to make a new part for you, I would reach out to people like Alec, Or a local blacksmith toolmaker. YouTube link
https://www.youtube.com/@AlecSteele/videos
Their instagram link is https://www.instagram.com/alecsteele/
https://jettools.com/media/akeneo_c...520_JWDS_1632_1836_Sanders_Edition_5_be0b.pdf
page 24 has a parts list
Thanks TritonFrom the exploded diagram it looks like the feed is one unit, and no separate parts of it listed, so its unlikely unless you contact Jet direct, you'll find that specific part for sale
But given what it is I would look more to either a repair, or find someone with a lathe to make it.
If a repair, as in welding it on, the two parts would need to marry up with extreme accuracy, and even then might need dressed on a lathe. So maybe the latter option of a newly made one would be the best way to go before you start wasting funds
