Rhyolith
Here is my North Brothers No.1555 Breast Drill:
North Brothers "Yankee" No.1555 by Rhyolith, on Flickr
Its made from the parts of 2 No.1555s that both had broken teeth and other minor issues, making this one which I hoped would be "perfect". It seems it if you pick it up and cranked it about however any load and it gets stiff as hell and eve jams on occasion. The whole thing is very clean a lubricated with generous amounts of 3 in 1 oil (which seems to work great for all the other drills).
I have been at a loss for what is causing this for the last 6 mouths. I have taken it apart, re-oiled, cleaned, switched parts, tested in different modes.... etc. It seems to be worst in "plain" mode in the higher gear and best in "double ratchet" in the lower gear; getting steady worse as you change the ratchet mode up toward plain... it is probably better in the lower gear due to the mechanical advantage. My only theory for ages is that there is some tiny difference in the geometry of the parts from the 2 original 1555s... but this seemed strange for what I assume is a mass produced tool?
However I finally made some head way with the acquisition of a No.1530 and noticed by chance that it ran infinitely smoother when the pinions where push away from the frame (toward the ratchet).
Untitled by Rhyolith, on Flickr
I wondered if the same issue was causing the problem in the 1555 to a more extreme degree, and indeed pushing the pinions away from the frame does make it smoother, but its impossible to do this in on the 1555 while drilling without losing a finger to the gears. I am assuming the friction between the frame and the pinions is the issue, oil does not seem to help much so grease?
I only have some really thick grease that I use in RC Car gearboxes... it does not work well at all in drills from experience. Recommendations?
