J H trim 5mm
SteveF
16 Sep 2013
Maidstone
anyone know where I can get above in white ......off the shelf in kent
I can buy 10mm from wickes for 2.99 for 2.5m
everywhere I look for 5mm is £7 +
Steve
for what I want:
J trim is a white plastic trim for edging plastic wall\ceiling panels
H trim is a white plastic trim for joining 2 wall\ceiling panels
used in bathrooms
my panels are 5mm thick
Steve
kevinlightfoot":2jfhjqfd said:
Thanks for that,I've not got much experience with plastics and you never find out if you don't ask .
thats ok, we dont all know everything, I for one dont have a small knowledge of building materialks
I guess I would not have a clue until i researched and got annoyed that twice the size was a third the cost
Steve
I don't think you'll find 5mm for less than the 10mm because it's down to the economics - the 10mm is used far more often as the plastic panels you are referring to are almost always sold in the 10mm variety.
Tbh the 5mm isn't worth the cost saving and you can compress it with your fingers - the vertical ribs are too pliable. Even if the 10mm wasn't that much cheaper I'd still not recommend the 5mm, unless the thickness was paramount in limited area.
info coming from just under 10 years experience in the trade / domestic plastics trade.
