It's the simple things that please me. :)
martinka
19 Jan 2013
Wakefield(ish), West Yorks
    121.5 KB
That's clever, very similar to the spoon and fork clipped together with the prongs being forced apart by the spoon. Then take a matchstick and put one end just between the lowest prong and rest the other end on a glass edge or just your finger. That works in the same way.
That's almost how I remember it from school, Malcolm, except I am sure we used two forks.
Clever indeed. it seems to be the same principle as the balanced eagle. How many of you had one?
    201.7 KB
I've only seen pictures of them. I wonder if it's possible to make one from wood or if it would be too light?
Not Four Candles then Martin 9-) lol
We were once in Barnitts in York and I asked for a few things, and tagged fork handles on the end. The chap serving me gave me a disgusted look as if to say, "Everyone thinks they are a bl()()dy comedian!"
Hi Martin. it would be possible, but you would need to find a way so the weight of the bird goes to the beak. Maybe if you combine 2 or 3 types of wood together: a light wood for the body, a heavier one for the head and an even heavier one for the beak?
Also, the proportions of the bird would need to be perfect.
This would be an extremely frustrating project, but let us know if you start and you manage to do it.
Yes, that would also work, balanced by the weight distribution, but always looks good Martin.
Cheers all, I'll have a go at making something that approximates the dragonflies. That's when it's warm enough for the garage. At the moment, condensation is so bad, it's like a shower around the bench area. :(
I don't think it would be too difficult to make one. (Famous last words!) I think more weight would make it more stable, but it seems to be mostly a case of getting the centre of gravity in the right place, as well as having the weight balanced evenly of course.
NazNomad":lx5zpxqu said:
Oh, I like those. Amount of wood might not be a problem, but finding somewhere to put them would be.
Getting this to balance was a little tricky, I had to cut 10mm off one of the long arms to get it to balance. Then the outer veneer came adrift, so I glued it back on and the weight of the glue threw it out of balance again. I haven't got a decent piece of wood big enough to make the big arms, so a better version will have to wait.
    118 KB
