I'm thinking ahead to the finishing of my multi hardwood stripy shelves and have become befuddled over the range of possibilities.
Previously I've used Danish oil (8-12 coats) for cherry window boards that I made, but have since been told about sanding sealer (some shellac, some spirit, some oil based), grain filler (or do I use plaster of paris?), carnauba wax etc and now have no idea of the best way forward!
I'd like to learn a little about when each of these could (or should) be used and what impact they have on things such as durability of finish, colour or discolouring of the wood and whether you use them together all the time?
At the moment I'm thinking I would plane the shelves to size, scrape as best I can and then apply sanding sealer, two coats of Danish oil and then finish with either Black Bison or Briwax....but do I need the Dainish oil at all? Should I be filling the grain?
I'm using a combination of Walnut, Mahogany, Iroko, Oak, Cherry, Ash and Maple...mainly offcuts resawn and glued into blocks to recycle as much as possible.
Any advice appreciated, but I understand that this is a huge topic....I should also state that at the moment I'm unlikely to have the time to be mixing my own, although I do like that idea for future projects, that and French polishing are probable one step to far for this student of the craft!
Thanks for any guidance as ever!!
