ChrisR":3ju140tq said:.....Don’t worry about (In Private) as it makes no difference on my computer, wither its on or off, this same annoying pop up message occurs on this site, together with the frustrating delays, and yesterday it locked up my computer completely, the only way I could clear, was to switch off at the mains supply, not good.
So there is clearly a site problem.
Take care.
Chris R. (OP)
That sounds a lot worse than what I am experiencing - I only seem to have this problem when going to the homepage to logonAES":1ms9igka said:Thanks for posting that screen shot showing how to set up for Private viewing. Unfortunately however (see below) this makes not a bit of difference - every time I want to move to another post or another topic, or scroll down, or post a reply (like now) my computer freezes up (the little blue bar down the bottom shows that "something" is happening - VERY slowly) and apart from that the computer is frozen for a long time. Eventually the message about a script appears (just as ChrisR described in his initial post) and when I'm asked if I want to stop running that script and press "Yes" then the little blue bar down below becomes full and I'm free to do whatever I wish until the next time it happens - i.e. the next time I want to vist another topic, scroll down, etc, etc. I haven't timed it but the freezing lasts a long time and makes useage very slow and most frustrating. Also, just like Chris R this has only started happening over the last 2 or 3 days, and also just like ChrisR, I am not having this problem on any other web site I visit and not have I experienced it before on UKW until, as above, the last couple of days.
AES":2neniq7c said:@Noel:
Thanks for your very (un)helpful one word post "Chrome"! What is it, and assuming I get frustrated enough to try it, where do I find it, how do I install it, and how do I make it work please?
Could you by any chance referring to a thing called Google Chromium???......
If this worked for you, what it has done is disabled any add ons, toolbars etc that run when you open IE - try not using any of the other settings except the command line and if the site is still fine, you can then, by process of elimination, find which add on/toolbar is causing your problemAES":12l9t5s5 said:running my IE 8 from the Run Command prompt works like a dream - TOGETHER with setting In Private filtering to ON and setting the "settings" of In Private filtering to the max number of sites allowed by the little counter window in the settings menu (it's 30 sites in my case).
