jasonwood
Hi all,
I've just routed the mortises for the cross members of the headboard and footboard of a bed I'm making.
The mortises are just over 3cm deep. Can't really get them any deeper with the router bits I have.
This image below shows the size of the mortise and the cross member that will eventually have a tenon cut and fitted into the mortise.
Based on these sizes and the application as part of a headboard, do you think 3cm is deep enough for the mortises or would I be better off chiseling the mortises a little deeper?
I thought about perhaps using a dowel to reinforce the joint, where you offset the hole in the tenon slightly so when the dowel is driven into place, it pulls the tenon tightly into the mortise, but this is softwood so I'm not sure if that would be a good idea?
Thanks for any advice
Jason
Jason
