jimmy rivers
Hi Folks of the UKW,
We’ve recently moved into an old property (200 yrs approx) which is of a solid wall construction and I'm looking for a little advice as to the best route to do some remedial insulation to our downstairs lounge walls and floor.
The previous owners membraned the inside of the solid walls and plasterboarded over a 2x2 stud work frame. The floors are a 5x1 T&G softwood board over 4x3 floor joists (no noggins) I know this as there is a small 2m sq pit underneath a part of the floor which is accessed via a trapdoor. The finish is great and the floor is nicely laid, however there is zero, zilch, nada insulation in the room and I can already tell that this is going to be a very cold room come winter :?
My experiences are more with Cabinet & Furniture Making so I would be grateful for any advice from those in the know on the most appropriate approach to tackle this project and the common pit falls... especially regarding... addition moisture membranes, working around windows and doorways to avoid condensation from cold spots and rotting studs/ floor joists
After plenty of Googling my initial considerations are:-
Part A:- Remove the fixtures (rads etc) and skirting before lifting the floor to slip Kingspan in-between the joists on battens(?). The joists are on bricks and slate packers approximately 3-4 inches off the dirt and I can see air bricks to the front of the house, so air circulation should be good.
Part B:- After the floor I would move onto the walls by either boarding over with insulated backed plasterboard (77mm) OR ripping off ALL the plaster boarding to insulate between the existing 2x2 studs (50mm) Kingsapn before re-boarding and skimming.
The Energy Saving Trust website suggests that I need to achieve a U value of no more than 30 W/m2k with regards to meeting regulations but I’m not sure if this is achievable with 50mm Kingspan?
I’ve attached a plan view of the layout and an (approx) exploded elevation to show the construction methods of the room at present.
All in all I sense it’s going to be a messy job and I am cursing the previous owners for not insulating when they had the chance! (hammer)
Thanks in advance,
Jim
Thanks in advance,
Jim
