Interesting plane on eBay
ydb1md
6 Apr 2005
Maryland
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=6219523375
Bean":3nwbsu1n said:
Could it be a broken rebate plane ??
No, no. [-X It's an "expertly machined" bullnose converted to a chisel plane. Didn't you read the blurb? :lol: The opening bid seems a bit optimistic even for an unbroken example. :roll:
Cheers, Alf
Cheers, Alf
I'm guessing that those old planes weren't made out of ductile cast iron? :shock: :lol:
There was a very handy plane at collage that had a removable front to make it into a chisel plane , not seen one since .
All right, newbie gives in! What's wrong with this plane? What are you suspicious of?
evie
Evie, it's a reasonable question. It should be more like this. Not so much suspicion, as sure and certain knowledge. :wink:
JFC, any of these by any chance?
Cheers, Alf
Ah. Broken off the front. I see now. And then cleaned up a bit. Does that often happen to those kind of planes? And (OK) what is the original for -- I see the blade sticks out all the way to the edges, so ... is it a shoulder plane? for the shoulders of tenons & stuff like that?
No, I went to blood & gore & it says it's a bull-nose rabbet plane. Which actually leaves me no more the wiser, except with a sort of horrifying animal image. A rabbet plane, I should think, is useful for cutting those narrow grooves (or are they dadoes?) on the edges of the piece of work. I think that's what a rabbet is. Maybe a rabbet is just a dado. But anyway, I don't know why you might want it to be bull-nosed.
AND, B&G says: "The toe section can be removed completely from the plane so that it can be used as a chisel plane. Stanley, in their tool propoganda, claimed that with the plane configured as a chisel plane it was useful for the removal of dried glue. There are better ways to remove that than to use this plane. However, the plane does function nicely as a chisel plane and is particularly useful when working rabbeted frames, where the stiles and rails join." So, perhaps it isn't broken but the "toe section" has been lost? In which case it might be fairly described as "expertly machined"...
question girl tries to look things up but she doesn't understand the answers.
Given that the bridge between the nose and the body of the plane is quite thin, I'm surprised we don't see it more often.
Sort of. Because it has a vestigial nose, it's difficult to use as a shoulder or rebate plane. It's purpose in life is to work a stopped rebate or dado, like, erm.... this:
In fact you might find the whole review helpful.
:lol: I know what you mean. :lol:
Curiously enough, they're rabbets, or rebates in this country. (Yes, confusing terminology changes depending on the country #-o )
Nope. A rebate or rabbet is worked on the edge of the work and has one side. A dado or housing is a groove or trench across the grain with two sides.
See pic above. Could be you never do, but when you do it saves an awful lot of chisel work. For some people it's just a generally all-round handy plane style to have about the place.
Not the #90J IIRC. That has a fixed mouth. Unless it's broken... That is to say, a fixed toe as part of the whole body casting.
Confusing, ain't it? :roll:
Cheers, Alf
No, no. It's an "expertly machined" bullnose converted to a chisel plane. Didn't you read the blurb? The opening bid seems a bit optimistic even for an unbroken example.
Yeah Expertly :roll: :^o
Bean
