Insulating/strengthening single skin outhouse
Remember that you may have to re-position your gutter and do 'something' with the eaves if you pack out externally. Just a thought. Best wishes.
If it helps, the 10mm "space blanket" from Screwfix (£75 for a 10m x 1m roll) is equivalent insulation to 50mm Celotex. You could fit this internally with 3/4" tile batten and over-ply. You'd lose only about an inch on each wall then.
Not heard of that one MMUK. Sounds well worth looking in to.
