NikNak
Hi guys, next question on my list to ask re converting our kitchen-dining room is....
Our house is relatively new (mid 80's i think) but it has a solid concrete slab floor. And in the winter it can get rather chilly underfoot.
All rooms in the house are either laminate or engineered flooring (apart from the hall/stairs/landing which have carpet) and even with various mixes of underlay etc they still get cold.
The best 'mix' i've found is to use the green fibre boards directly onto the concrete floor followed by a layer of the very thin (2mm.?) polystyrene foam on a roll, sold as underlay, with the flooring on top of that.
However.... we'd like to put ceramic tiling in the newly converted kitchen diner. I'm keen to explore underfloor heating, probably/possibly run from the central heating system. But the other half isn't.
Sooooo.... i'm now thinking about using the Backer-Boards you can get for insulating the sub floor prior to installing underfloor heating etc. (the ones with a polystyrene middle and a cement covered mesh either side....) and just wondering if that will work/improve the cold from coming up floor the concrete slab.? I'm thinking of using the 12.5mm ones, as that plus the thickness of the tile plus adhesive etc will come to a similar thickness as the engineered flooring/underlay in the hall.
Any thoughts....?
Nick
Oh.... almost a p.s..... have any ove you got underfloor heating (electric or wet) and care to comment on the running costs.?
Any thoughts....?
Nick
