I found this saw set and wondered if anyone has any imformation about it ,it would seem easy to use and it adjusts for size of teeth so it should be ok for all saws even dovetail saws .
My main problem is that there is a little flat spring that comes in from the back and lifts the hammer after each set, which is broken.It should be easy to grind a new one from a lock sring or similar but how do i drill a hole for the holding screw.The spring is about 1 1/2" by 5/16" with an 1/8" hole in one end (measurements from memory).
