Mr P,
I'm not sure about scrapping it as it is my first infill project, and despite it only being a casting at the end of the day, I like it!
Maybe I'll put it somewhere prominent in my workshop and keep it as a reminder
If there is a member here who can be persuaded to sort it for beer tokens, that would be great, and thank you for starting the topic in Metalworking.
Another infill plane would definitely be nice, and a brass one could be nice! That Bristol Designs Plane is nice after all...
Do I detect a, all be it slightly tarnished, silver lining?! :?
Andy,
Thanks for the image, it seems familiar! I think I must have seen it when I was looking for possible solutions.
I think the conclusion I came to with this method is that due to the position of the break, there is little height for a splint, so there would be reasonable leverage on the screws in use (?), which might cause them to crack out again? But I don't know for sure, so it remains a possibility!
The part completed infill does look very interesting, but it would mean a trip to Bristol Designs, which although not out of the way, must still be an hour and a half drive from me?!
Jimi,
If I did have it welded, you're right in that it certainly will not be invisible, as rarely welds truly are, but even less so on cast as I think the weld is a different colour anyway?!
I hadn't thought about grinding a new profile into it, but as you rightly say anyway, there simply isn't enough left for anything suitable.
Its looking more like it will have to become scrap...
Pete,
I do like an easy option I must say!! :lol: On a serious note though, it seems like a lot of work! Especially when I can't claim experience in having done dovetails in metal either! I would definitely like to have a go though! Maybe some parallel shapes first rather that this though as the back of the plane seems like a challenge for dovetails :shock:
Dick M,
I've done a little brazing, but it must have been 3 or 4 years ago now and that was on a model I made that had a small piece of sheet steel in it, -the heat sink that the sheet steel created meant it took me ages (must have been close to an hour) and took two brazing torches to heat the model up enough to melt the braze.
But it must be worth a try
Unlucky with the Stanley though, hope it wasn't too expensive!
Now, to find that local engineering shop...
James,
I really am, but I think you're right though, it might be time to get another one and re try
Thanks again,
Harry
