Hi all
In the process of a new workbench design in which the router is part of it, along the lines of Denis(Hooked on wood) but more modular. Now I am nowhere near as experienced with the router or router table as many on these forums so looking for feedback and your thoughts as I have some issues that could send me down the wrong path.
I currently use a Kreg table and Triton router, it works great but takes up floor space which I am short of so hence the new bench, but I want the repeatable precision of the Incra fence. Now this sticks out behind the fence which requires a deeper worktop, about an extra 200mm. I want to use either the Benchdogs plate or make one like Denis so that the fence can be easily removed when not in use and this also provides a course fence adjustment by using the holes. It also means the positioner can be attached to keep the extension shorther and more rigid. Now the Incra is 430mm long, does it really need to be this long? I have about 150mm of fence adjustment on my Kreg and have never had a situation where it has prevented me from doing a task so would a shorther positioner be the answer if Incra made one? It will not really be much cheaper as a lot of the cost is in the main body and adjusters but could be more helpful to those with limited space. The other option I have thought about is to have a hinged flap, like a table at the back. When needed the bench is moved forward and the flap raised then the fence attached.
Has anyone an accurate 2D drawing of the Incra positioner?
