Steve Wardley
Some time ago I purchased the Incra ibox finger joint jig but have not had a chance yet to use it and the main reasons are twofold, firstly the rail that slides in the table saw mitre track is too big for most if not all British/European slots and this means having to make a smaller rail perhaps out of acetal or something of that nature, secondly because British table saws are in the main not able to take stacked dado blades (and yes I know there are exceptions) it means that all your finger joints are likely to be the width of the largest kerf saw blade that will fit the saw arbour, probably around 2-3 mm.
This means the other alternative is to use it with a router table and there again my shop bought router table has slots too small for the rail so now I'm going to have to build a new bespoke router table with Incra mitre slots to be able to use the ibox.
I wonder if any others had come across these hurdles and how you have overcome them, I clearly should have done more research into the ibox but I read good reviews on the product so I probably would have still purchased one.
Your views are welcomed.
