I have bought a lot of stuff from axminster, and have had some good and some that was, shall we say, a liittle rough around the edges but on the whole, I have been happy with the service.
For my birthday last month I ordered a bench drill press, having put up with a wolf stand and a power drill combination for almost 20 years.
Folk with good memories will know the problems I have with axminsters carrier TNT. They believe I live in a different country than I actually do and try to deliver my things to istanbul. So I have to give them a friends address. They still get this wrong and send stuff a 100 miles west to where I actually live (3 out of 3 deliveries wrong so far. why do we have postcodes?).
Ok, that said, my new bench drill arrived tuesday (4 days late due to wrong depot and re routing). Unpacked it and step one was to bolt the pillar to the base with the three 8 mm bolts provided. Problem? oh yes, I'm not clever enough to get the 8 mm bolts to fit the 1/4" threaded holes in the base.
Luckily my engineering skills are a bit higher than my woodworking ones so i drilled out and retapped the cast iron base.
When I got it all assembled I discovered the rotating table central hole does not line up with the drill. An 8 mm drill fouls the front edge of the large hole. Even I'm not good enough to re-cast the table so I shall have to live with that.
When i powered it up at the wall socket there was a loud rapid clicking noise from the NVR switch. Again, i know about electricity. The switch had been wired backwards.
Onwards, as they say.
In the box I found a neat little plastic knob that looks like a push / pull thing. Even with my best magnifying glass I cant find a place that this belongs despite consulting the full colour manual that is very confusing because it covers about 6 different models at the same time.
Right, I've re tapped the holes, re wired the switch, removed the surplus to requirements knob. Its time to set the belt speeds.
The motor is on a side pivot plate with a bar to push the motor into belt tension. Theres an 8 mm bolt to tighten down on the bar to hold the motor. Yes?
No.
There is no thread inside the lug that the bar slides through. Now I'm in trouble for the first time. The 8 mm bolts falls into the hole, so i would need to tap that out to 10 mm. Except there isnt enough meat in the metal at the sides to allow 10 mm thread.
I'm considering options right now, I suspect I will have to make a threaded bar with locknuts either side of the lug (wheres Nolegs when you need him, huh)?
Ordinarily I wouldnt have gotten into it and just repacked the thing, but due to a 2 week each way trip and the cost of shipping it back, chucking it back at axminster is not going to happen. I am going to persevere and get this piece of chinese at its very best engineering working properly.
I cant use the words I want to use to describe this machine, blacksmiths would die of embarrassment. I was eagerly awaiting it, now, its not so much fun.
Beware if youre thinking of buying an axminster bench drill, unless you live close enough to one of their stores to be able to go swap parts out till you get a good one.
No.
