Hi,
Sadly the depth stop on my Clark drill press has broken off!
It appears that only a thin bit of plastic was holding the threaded rod onto the housing.
Wondering if anyone has some bright ideas on how to fix it, hopefully an idea that would last not just a quick fix
I could reuse the threaded rod and put a bolt above and below the red housing, but I’d loose a lot of rod height, alternatively I could make a new part somehow maybe from a section of 10mm threaded rod and cut down one end to fit the flag onto?
