Froggy
I'm trying to get hold of Ian the bandsaw blade, but everytime I send an email to [email protected] I get an 'undeliverable' message!! Ian can you please pm me I'd like to but a blade or two please?
matt":3uba3kfg said:Odd. I've been corresponding with Ian at that address for the last few days without a problem.
I too sent you mail but had no reply, need new blade send me pm if you are interestediajon69":1brdbq39 said:PM sent, not aware of any problems with the email address - you could also try [email protected] as both are set up and as far as I know both working ok!
Ian
motownmartin":qd6e9vqg said:I too sent you mail but had no reply, need new blade send me pm if you are interestediajon69":qd6e9vqg said:PM sent, not aware of any problems with the email address - you could also try [email protected] as both are set up and as far as I know both working ok!
Ian
Thanks Ian, got your PM, the email must be floating about in cyberspace :?iajon69":2uzgpf94 said:motownmartin":2uzgpf94 said:I too sent you mail but had no reply, need new blade send me pm if you are interestediajon69":2uzgpf94 said:PM sent, not aware of any problems with the email address - you could also try [email protected] as both are set up and as far as I know both working ok!
Ian
Hi Martin
I definitely replied to your email - just checked and it was on the 7th of April. I won't publish the email address that it was sent to on here, but will PM a copy of the email straight away.
Ian
motownmartin":3nzmm976 said:Thanks Ian, got your PM, the email must be floating about in cyberspace :?iajon69":3nzmm976 said:motownmartin":3nzmm976 said:I too sent you mail but had no reply, need new blade send me pm if you are interestediajon69":3nzmm976 said:PM sent, not aware of any problems with the email address - you could also try [email protected] as both are set up and as far as I know both working ok!
Ian
Hi Martin
Ian
No, not in there Bob, I must have a clone somewhere.9fingers":2ln5ez71 said:motownmartin":2ln5ez71 said:Thanks Ian, got your PM, the email must be floating about in cyberspace :?iajon69":2ln5ez71 said:motownmartin":2ln5ez71 said:I too sent you mail but had no reply, need new blade send me pm if you are interestediajon69":2ln5ez71 said:PM sent, not aware of any problems with the email address - you could also try [email protected] as both are set up and as far as I know both working ok!
Ian
Hi Martin
Ian
Or maybe stuck in a spam folder??
Bob
