I have a Startrite 401S bandsaw that i purchased from Yandles in 2003 at a cost of just over £1,200. I needed a large single phase bandsaw at the time for ripping down some oak beams for a house build.
The problem i had is that the blades would break after about a couple of months of use. I tried various different makes of bands but the problem still persisted.
As it was under warranty Startrite send down an engineer to check the machine over and found no problems with the machine, (paperwork available). So thinking i was doing something wrong i set up the blade for the engineer to check and it was ok.
Again the blades kept breaking so i commissioned a local machinery engineer to check the machine over also my blade setting and again all was ok.
So in a year of occasional use i had about 8 blades break, having a saw bench and little use for a band saw it got resigned to a corner of the workshop.
I a'm now looking to sell the machine as the space is needed and don't have the time to spend trying to find out whats going on, so if someone wants a large bandsaw and has the time to sort this problem then get intouch.
For anyone who may have any idea's as to why this is going on, the blades start to crack at the base of the tooth gullet and if not spotted in time will then break in use.
Or do i just put it on ebay and don't mention the blade breaking problem.
