I want a hardpoint!!
MIGNAL
6 Nov 2005
W.York's
:shock: :shock: 5 or 6 years ago I should have been struck down by a lightning bolt. I went out and bought a Stanley Jetcut saw. It was a small panel type or 'tool box' saw, perhaps only 18 inches long. I used it for a few months (DIY -honest!) before a friend borrowed it and promptly had his tools stolen from his van. It was a damn good saw and cut extremely well. Now it seems that the Jetcut is no longer made but Stanley do make a 'finecut'. Is that the exact same thing? All I remember about the saw is that it had teeth similar to the Japanese saws.
That's good to know for when my little Sandvik toolbox saw wears out. I've had it for about 15 years now, it cuts like a knife through butter even though I use it for everything, including pruning the palm tree and other forbidden uses. Definitely the best saw I've ever used, nothing wrong with hardpoints.
If you want a good fine crosscut, the Bahco laminate saw is brilliant. All these fine saws benefit from having the lacquer stripped from them - they are much smoother in use.
I found the bahco profcut (orange blade with black writing) to be the best hard point, from what I remember of the time before I started to refurb and sharpen my own saws. I think it had a slight amount of set on the teeth (most hardpoints then DIDNT). Also the blade was thicker and stronger than most. I havent used a disposable for around 10 years now though, the models have probaly totally changed by now...
I agree with previous poster.....
+1 On Hardpoints. I have always used a Bahco (sandvick) 244 and decided to try a Wickes Fine cut for £8.00. I was delighted with it, handle was much more comfortable and the cut was really nice. I think it might be a re-branded irwin.
I've tried various hardpoint saws including Bahco, Irwin and spear & Jackson but my favourite by far is the Stanley Fatmax fine cut - comfortable handle, rigid blade and clean cutting, which is more than what can be said about the S&J Predator-something.
Hardpoints,, horses for courses,,used and abused quite a few on building sites,,recently bought a pair of S&J predators from B&Q for a tenner the pair,,just sharpened and set a Disston D8 which took me about a hour an a half,,with labour rates around 20 to 25quid an hour that is a few hardpoints,,but there sure is something about using the Disston,,a tool that used to belong to an uncle,,just wish i could be as good as he was,,
,,,,,,joe,,
or....................................... you could try some Viagra I hear that will give you a hard point. :shock:
I have a couple of shed saws as I call them - both Stanley hard points, one 8tpi and one 7tpi
Use the 7tpi for most things rough (including gardening)
I also have a Diston (plus many others :)) and know exactly what you mean using this - just feels right somehow
