I turned something and it was not firewood.
frugal
29 Dec 2007
Dursley, Gloucestershire
Okay, it was firewood. It was a piece of cherry from the firewood pile that we decided was straight enough to try to turn:
The first exercise in all of the books seems to be beads and coves. The beads were done with the skew chisel and the coves with a detail chisel. The finish was shellac sanding sealer and beeswax.
I started with a cylinder, then made 7 beads, then turned 3 of the beads into coves with a fillet between them. Admittedly I chose the three beads with the most catches to be the ones I removed to make the coves ;)
After a few false starts and horrible catches (you might notice that not all beads are the same height ;) ) I think I have begun to figure out how to use the skew.
I think it might end up as a candle stick. So my first piece of face plate turning might have to be a base for it...
That is incredible wood. If you can sort out a way of hanging it vertically it'd make a lovely piece of art or maybe a large light pull
Getting two beads exactly the same is not the easiest thing to do IME as the slightest twist changes the profile. You've done a good job there
You've done really well there. I spent the day with Richard Findley and didn't get close to that!
Frugal,Good effort and as Pete said not easy to get everything right first time, but it's a fair good effort and a lovely piece of wood onwards from here. REgards Boysie
On your way to an interesting set of door knobs frugal. as Pete says shame not to find some use for your efforts.
WOW ! What a piece of wood !
Definately try and find a use / purpose to use it in .... be an 'insult to nature' not to ! 8)
Its great !
Nice work on the beads & coves ... if thats a 'first go'... then thats one teriffic effort, Frugal ... well done indeed . 8) 8) 8)
Hi Frugal,
Its a brave man who starts with a skew chisel. :shock: :shock: though if you are not worried about the potential problems it is a great tool to use.
I agree with George, that looks more like laburnam than cherry.
Welcome to the slippery slope . :D :D :D
Mike C
Getting identical turns is not easy!! why do you think I always say 'all my pieces are unique, you will never see two exactly the same!' :lol: :oops: :roll: but that is a very good try at it. :wink:
cornucopia":3fyposmr said:
well done :D
the wood is definatley 100% Laburunum though
hmmm. it looked like cherry from the bark... has a look in the wood piile for turnable pieces... oops, it is full of scraps of laburnum and yew. I don't appear to have any practice wood :twisted:
No such thing as 'scraps of laburnum and yew' just blanks for smaller pieces :roll:
