Hi Mike,
These are the homemade hollowers which I`ve just finished making, which I mentioned in an earlier post.
13" X1/2" silver steel shafts(Ebay), copper plumbing fittings for ferrules, 3 HSS tips ground from a single rectangular piece similar to those in Jason`s link above (I got mine from the Ashley Iles stand at a show.)
Holes bored in the shafts with a cobalt drill, fixed in place with epoxy.
The bent tool was heated with a butane torch and bent in a vice (hard work!)
I`ve just tried them out briefly today on some scrap. The hooked version chatters a bit, possibly due to the toolrest overhang necessary to clear the bent section and the length of the tip which is perhaps a bit too long. Perhaps also, as Paul suggests, the epoxy allows a little flex. The other two tools seem to perform well and leave a good finish. An advantage of an epoxy fixing over brazing is that the join can be softened by heating to allow removal of the tips should this be necessary. Another advantage for me, is that I don`t have the equipment or the know how for brazing.
If you were going to make tools like this, I`d suggest grinding the tips to final shape before fixing in the shaft. It`s much easier to control the operation that way. Sharpening thereafter will be by hand with a diamond file.
Total cost all in for the three tools including timber for the handles was about £30, so well worth a shot, I think.
Hope this is of some help,
Ian
