amadeus
Hello,
I have a very stiff tailstock for a Myford ML8 and I've been staring at the very helpful diagrams of the Myford ML8 posted by @HappyPixie.
I've removed the retaining screw, thrust ring and hand wheel, and the barrel locking lever and washer.
I'm not having much luck removing the barrel itself. Can I check:
Amadeus
- Does the barrel come out of the front or the back? Given the barrel locating key I would imagine it comes out the back, unlike videos of other tailstocks I've seen?
- Do you need to remove the padbolt first, and if so, how? The padbolt is fairly wedged and it's unclear if I need to tap it down and out or pull it up?
Amadeus
