How to measure a recessed space accurately
glynster
16 Apr 2014
Reading
Hi, I'm a beginner so apologies if this is a stupid question, but how does one measure a recessed space accurately - for example, the exact distance between the innermost space between 2 rails or aprons? The joinery techniques of folding in a tape measure is only accurate to approx 2 to 3 mil at best and whilst I can measure the outside of the recess with a rule or tape that assumes that the faces I am trying to measure are perfectly parallel which they rarely are especially in joinery. Is there not some kind of expanding ruler that is accurate to a mm at least? I have looked for one but cant see anything suitable and it seems whatever I try is sloppy and leaves me feeling ashamed of my man skills :lol:
I measure a few inches one way, make a little mark, measure the other way and add both together.
Have a look at a vernier caliper, will measure internals, externals and depth very accurately.
Even a cheap digital one will measure to a tenth of a mm.
Jon.
Pinch rods, then use a normal ruler.
BugBear
Thanks for the tips. I like your idea Mark (no pun intended) proving I marked with a blade I shouldn't get much cumulative error. I dont imagine I could get digital vernier gauges larger enough for my needs. I must admit I have heard of but never understood the "story stick" principle - but sure I would have the same problem in that if would either be too short or too large to fit inside? I will google pinch rods and check that out.
Paul do you use your own sticks for the Veritas bar gauge? Do they have to be exact? I could imagine 2 lengths of dowel being ideal - I'd just need some kind of rudimentary clamp that I could tighten to lock them while I transfer the measurement. I was thinking if I drilled the diameter of the dowels through a small block of wood and then bandsaw cut the block in half along the drill hole lengths, that should remove enough materials and give a profile to provide a strong grip on the dowels when the "sandwich" is clamped - I'd just then need the right screw or clamp - any ideas?
Yes, you make up your own wooden pieces. I have three sets of different lengths and find them very useful when making shelves and such like. It's worth having something that is easily adjustable because internal spaces are seldom square and you often have to take several measurements. The good thing about having wooden rods is that you can mark them with a pencil and write on them and then re-set the measurements exactly.
If you Google "pinch rods images" there are various examples if you want to make some clamping devices yourself.
Cheers :wink:
Paul
There are tape measures designed specifically for measuring internals - I use a Talmeter and there's one by BMI called a Visio
- also available in Festool green for a slightly higher price ;)
HTH Pete
Edited for clarity
Not the cheapest solution, but probably the easiest - I have one of these http://www.amazon.co.uk/Bosch-DLE40-40m-Laser-Rangefinder/dp/B002LJF7YM
You just hold it against one wall, check the red dot is on the point you want to measure to, and press the button.
I made this,
Works o/k I remade the chock from hardwood to make work better.
This is what I use - an offcut of plastic mini trunking. The top fits on the base just tight enough to adjust for a snug fit and it cost nothing.
In the picture I am measuring between uprights on a bookcase so I can custom fit a shelf.
The above are good tips - I really like the Veritas bar gauge myself (except it has a habit of being too long or too short!).
When I am measuring a recess for say a shelf or countertop, I make up a template with 4 strips of plywood and some corner or bracing pieces which I fix together one corner at a time using hot-melt glue - never fails.
Thanks, this is fascinating to see and hear of different methods used. I would have though that the problem would have been more common than measuring of shelves etc for those who build with a relative dimensioning methodology.I love the dowel mechanism Pete and it is just the kind of thing I have started thinking about. What are the perpendicular holes in the chock for? How does it lock/fix?
I also like the trunking idea for a cheapo (post-apocolyptic-chic) solution but I'd imagine that it would stick along its track or flex and give a less accurate measure.
HTH Pete
Edited for clarity
We used to stock the BMI Viso tape but can no longer get them so we have replaced them with Richter 3m/10ft Pocket Tape Measure with Sight Window. The same tape but a different colour and cheaper but made in the same factory, we tend to sell them to window fitters, blind makers and to Chrysler USA :!:
Other people buy our WoodPecker Story Sticks but these are more for workshop use.
Cheers Peter
What an interesting thread - I've learnt about some tools I didn't know existed.
It strikes me that there are two different problems here. The difficult one is to make a tool which gives a numerical value, which can be recorded, then used later to make something to the required size. That's what the window measuring tools do.
The other option - which is much simpler - is to make an adjustable stick which is fitted into the space then immediately transferred to the wood that needs to be the same size. This has the advantages that the tool needs no graduation and that you can make the fit as tight or loose as it needs to be. Also, there is no risk of transcription or calculation errors.
I much prefer that way of working whenever possible.
